any idea on what game this board is?I need to make an adapter to test it but can't figure out what game it is,it has no markings,so im guessing it's a bootleg of some sort,looks quite old
Hi. Any chance of a higher quality pic and then we might be able to work out some of the pinout with you. Obvious stuff - no markings on the ROM labels or PCBs?
To start off put your test meter onto continuity or the lowest resistance setting, put one probe on the bottom right leg of a 74-series chip (notch to the left, chip positioned with its longest dimension horizontally) and then move the other probe across each edge connector contact until you get a beep or a very low (0-3ish Ohm) reading. That's ground.
Put the probe on the top left pin of a 74-series and repeat to find 5V.
Video is a bit more tricky. There will probably be a resistor network to create the analogue RGB signals and for that we need a good quality shot of the edge connector and the components around it.
hi,thanks for the quick reply,sorry about the crap photo,the roms say QB so im guessing either quarterback or qbert?,I have a rom programmer,If i read a rom,how do I check what game it comes from?mame?
