Gyruss Save Kit
OTTOTHEMADANDEVIL
Will gyrate for Gyruss
328CR
Okay, the inevitable has happened.
Fully working Konami Gyruss board – Check
Save Kit, Kit – Check
Soldering stuff – Check
2 hours later broken Gyruss board – Check
You’d have thought by now Id have learned not to mess with things….
I followed the instructions… took my time and all I get now is a load of junk on the screen……
Im not sure if its my incompetence or a bad chip… everyone else who Ive asked that’s fitted them says there the S**T!!
Uploading a video now…..PLEASE HELP
Equites
Chief Sheesher®
35 (100%)
3,329CR
You have not said what the Save kit consists of?
Eprom + NVRAM?
CPU Daughterboard + Eprom?
You sure you have not lifted/damaged tracks?
Did you wear a lovely wooly jumper while doing the install?
Have you tried removing the Save kit?
Sheesh.
OTTOTHEMADANDEVIL
328CR
Eprom + NVRAM
I wore a Joystick Junkies T-Shirt......Its green...
I don't think I damaged any tracks......
I'll try removing the save chip now, would that reset it to normal with the NVRAM still installed?
I cut (snipped) the old chip out....
Equites
Chief Sheesher®
35 (100%)
3,329CR
Green T-Shirt may be the reason.
Try removing new Eprom, replace with original, remove NVRAM replace with original.
Re-try and report.
Equites
Chief Sheesher®
35 (100%)
3,329CR
Ok, remove green T-Shirt replace with manly one. Replace just the eprom.
If NVRAM is good it should still work.Equites2014-03-17 18:00:11
Equites
Chief Sheesher®
35 (100%)
3,329CR
Would a JIM BEAM T-shirt offer better results?
I'd have to confirm that.
Is PCB no longer going through initialization anymore with original Eprom? (the grid etc...).
Different jiggly mess is a bit vague. Need more data.
OTTOTHEMADANDEVIL
328CR
OKAY!!!!
Who wants to earn some folding money?
Im sure I saw a post about board repairers....
Im wrapping and boxing this up now, I cant risk doing any more damage.
Who's my best bet?
