Hanatrex Polo problems
Adamski
386CR
Hi All
Just brought a cab with a Hanatrex Polo and it's giving me problems.Basically I get intermittent green horizontal lines and also grey lines.I can get rid of these by fiddling with the remote board and the connection wires block but they always come back.The picture also seems to "jump" around the edges between different brightnesses like it is "glowing" sorry for description but it's the only was I can explain it.Any ideas?
Sad as the cab is great
tb2000
3,568CR
Intermittent green/grey horizontal lines could be bad/cracked solder joints or trace(s) somewhere if you can make it go away but could also be a bad green neckboard transistor. Could also be a bad rgb chip (the multi pin one on the neckboard) just being a coincidence that it goes when you move it about. I know what you mean about the "glowing". It sounds like a B+ regulation fault. Could be bad caps in the psu somewhere. Also the glowing fault (if its the type where it also changes background brightness with image changes) is a common Polo 1 fault (and Polo 2 sometimes), i've had it quite a number of times. I've never found the cause despite going over every neckboard component but i've fixed it pretty much every time by swapping out the neckboard for one from a parts chassis.
