Hang-On cab issues thread (Graphics/Power)
36CR
I'm finally trying to get my Hang-On cab fully working and as I encounter issues I will post them in this one thread in the hope that somebody can offer advice.
I had the board set repaired by Mark/RetroClinic a couple of years ago and it was (and mostly still is) fully working. The current issue I have is that no sprites display on screen, and from previous discussions with Mark I believe it is a voltage issue.
At the PSU the 5v output measures at about 5.5v on a multimeter, but if I measure at points on the PCB (e.g. on the ICs) the voltage has dropped to 4.5v or lower, and As I understand it this voltage drop is the source of my problem.
So the question is, how to I rectify this? I can adjust the 5v on the PSU but am concerend about pushing too high in case it blows something on the board when powered on. So what other solutions are there? A different PSU? Something to boost the voltage on the PCB or regulate it so it can't go above a dangerous level if I do boost it at the source?
The second issue I have is that when I did the memory test the other day, it shows the IC 74 being bad.
Presumably the solution here is just to pull the chip at that location and replace it witha good one? Or is there more to it than that? Or could the error just be being shown because of the low voltage?
All advice greatly appreciated
witchfinder2022-08-31 09:50:07
paulcan69
945CR
Although those self tests on older boards are a bit hit and miss
I think you would have to start there...
I'd certainly be carefully desoldering that chip adding a socket and adding a fresh new one
It might be it's shorted out internally and pulling the voltage down across the whole pcb
It can also be a logic gate chip connected to it which is actually faulty so like a "74LSXXX"
But given the age of all these rams chips now (And they work hard and get hot) - so it might just be the ram
Look for IC 74 printed on the pcb, get the numbers off the ram get a new/equivalent chip
Renew it and retest
Then maybe look at voltage 2nd
But yeah don't just turn it up if already at 5.5v at psu
It can be psu has gone weak
Sometimes wires going to the pcb as well breakdown/corroded
Sega looms are pretty good normally
If it was a "homemade" jamma cab sometimes the looms are cheapo and not enough wires on each rail, but yeah Sega looms are good quality
But me, I'd be changing that ram first
I've replaced more ram chips than anything else on pcbs over the years
2nd to actual ROM chips
Good luck!
5,325CR
To clarify, are you saying that with everything powered, you get 5.5V coming out the PSU, but it's only 4.5V measured at the ICs on the PCB?
That seems very unlikely - the voltage drop has to be present somewhere, it doesn't just vanish, so the cabling or the connectors would be losing a volt and burning off a few watts of power. Or maybe you're not probing it quite right on the game board.
Or do you mean you have 5.5V on the PSU with no game board connected, and when you connect the game board the rail drops to 4.5V? That would suggest a crap/failing PSU.
36CR
Yes, that's what I'm saying. It is possible I'm measuring at the wrong pins on the IC - It was basically one pin at each end of one side, which I think is right?
If there are specific points/chips I should be measuring at then please educate me
I will look to replace the RAM and see how it goes after that - any suggestions on where to source replacements from? I say replacements because another one was reported bad the last time I powered it on
5,325CR
Ah, that's kinda right, as long as you do it the right way around and pick the correct type of chip.
Find a 74LS or 74HC device (there'll be lots of them) and with the label the correct way up, put the ground probe onto the bottom right pin and the red probe onto the top left (so pins 10 and 20 on a 20-pin device)
