Hantarex 900 width adjustment
mysticmonk
1,051CR
Was fiddling with one of these recently and it has slight borders horizontally. Nothing terrible.
Got the manual and went to adjust the horizontal amplitude, but the plastic piece looks kinda ropey, worn down. So I decided to leave it alone.
However, I read elsewhere that adjusting the horizontal linearity coil can get the desired effect. It has a square hole.
1) do I just turn the square hole? (I try not to assume anything, even the obvious!)
2) what exactly does this linearity coil do? What should I expect?
Is it a workaround for adjusting width?
tb2000
3,584CR
Is it a MTC900 or do you mean MTC900/E?
On a MTC900 you can usually use the width adjustment on the east/west board they nearly all use.
On the MTC900/E, the linearity coil will adjust the width a bit but you'll find that (usually) the horizontal linearity will be altered (as you'd expect really!) Just turn the square a little. Really though you should be turning the width coil, although these do go brittle after so many years. That said, some are still perfect. With horizontal linearity, imagine a crosshatch pattern on the screen. You'd ideally want all squares to be equal width. Adjusting the horizontal linearity will make some columns of squares narrower and some wider. If they are already not equal you need to adjust it so they are equal, or as close as you can get.
Oh, and try to do it turned off if you can, especially doing the width coil. That's unless you have a proper plastic adjustment tool (metal will heat up pretty quickly!)
tb20002019-04-23 22:03:40
mysticmonk
1,051CR
That's excellent, appreciate it! You're right of course, it's the 900/e.
I wouldn't mess with the amplitude or coil while turned on in a cabinet, very tight space!
I only want to gain a cm or 3, so I'll give it a twirl :)
