Hantarex 9000/a 9000a monitor
biglouie
83CR
I wonder if I can ask some advice?I believe the below is a Hantarex 9000/a
I need to add the power connector from the iso transformer to the small green plug on the left.
The 9000 manual is different to the 9000/a and I am struggling to find a schematic for the 9000/a
Does anyone have a schematic or have one of these and can give me a heads up on the pin out please?
My search skills have failed.
biglouie
83CR
Hi both, thanks for your replies.
Would you have a link to that work, so I can have a look at it please?
I have the power correctly wired in now I believe.
For others in need, Pin 1 is 128v, Pin 2 is 0v. The pins start on the left hand side for the smaller 4 pin power connector. Pin 3 is 220v and Pin 4 is 0v (these are for the degauss circuit and can be split from the main power in to the iso
I now have to work out, how to wire up the 6 pin connector. I have 2 yellow wires and 2 brown wires into a connector (from the yoke?) that needs replacing with the Hantarex green connector, so I can get it into the motherboard.
This is the current connector. So I need to work out the pin out for the green connector now. :)
Then this can be plugged into one of the two, six pin connectors on the board. I also need to know which of those two adjacent connectors it goes in! :)
I think I am dealing with CM below, horizontal and vertical yoke wires?
biglouie2022-04-05 19:28:50
biglouie
83CR
Hi there. Apologies I didnt understand
If I know horizontal impedance then I guess I'll know which is horizontal and which is vertical
Thanks for continued help.
I'm also going to need to find a 2 pin green Hantarex connector for the degauss wore to plug in. Will have a dig about, not sure I have one.
