hantarex 9000 horizontal width problem
Megaman255
3CR
Hi! I have a hantarex 9000 and the width is too wide for the screen. I read that if I adjusted the bridge coil it would help sort it out. Before I do that I just wanted some advice really. Would this help? Also which way to I screw it and how far?
Cheers in advance
Will
Megaman255
3CR
Adjustment biard? Is that the pots on the back of the monitor? Yes I can go bigger but not smaller.
I did some reading up and adjusted the horizontal linearity thing and improved it a lot but its still missing some screen?
Thanks for reply!
Megaman255
3CR
Ah mint!
OK next question...
Is it difficult to remove monitor chassis?
Will I have to do anything like discharging it?
Cheers again!!
gunblade
9,150CR
the cap is located inside the heat shield so it would be wise to remove the chassis,mtc9000 do hold a small amount of charge so it would be advisable to discharge the anode
the reason i suggest a bipolar cap is because not all mtc9000 are screen printed to show the polarity of the cap-unless of course you note this as you remove
RGP
Meeter & Greeter
2,039CR
Yep, i've had about 5 with this problem over the last few years and I think I saw BP on the schematic revision I was looking at so i've used that ever since, worked a treat and you will need to re-adjust the coil again after.
As said by Gunblade - C42 is your target here.
It is cramped down that region next to the flyback so a steady hand and long nose pliers/long tweezers will be needed.
Megaman255
3CR
Hi I'm trying to find the correct capacitor and I believe this is the right one.
4.7uf 50v 6mmx11mm non polarised (Bipolar) 85c x2 Panasonic.
Wanted to make sure before I put it in!
CheersMegaman2552014-08-18 18:57:57
3,585CR
That should do the job although you should get 105oC ones (rather than 85oC) if you can. If this doesn't make any difference then the next thing to do is to check the width circuit, which includes a transistor among other thing I think. I also had a 9000 with a width problem a while ago where the width circuit was fine and it turned out to be a poly cap at fault.
Ordyne
1,282CR
You don't need a none polarised cap for C42, just make sure you put the negative leg to the large negative track at that cap location which covers a lot of the chassis
Stevros
506CR
Hi, i have a similar problem on one i recieved today, when i switch it off and on again the screen is normal, it then stretches on its own the longer it is on.
Will replacing the cap fix this?
All colours were way out too but seem to have sorted that from the neckboard pots.
