Hantarex 900E sync
jengineer
49 (100%)
1,205CR
I have a Hantarex 900E monitor which doesn't sync,
its a bit different to any other 900E I have worked on,
its 110v and the RGB plug is different, but it's marked up R, G, B, C, H, V
I have tried putting the sync wire on H and then on V and then joined them both up but it still doesn't sync
there is also a 3 pin plug behind the RGB plug which I don't know what its for?
the tube is very nice, it is housed in a Electrocoin frame with switches on the left hand side going to the yoke to switch the picture upside down etc
jengineer2016-07-14 23:07:25
RGP
Meeter & Greeter
2,039CR
900E/USA version.
Similar video input to an Electrohome G07.
Front 6-pin connector carries positive sync. Back 3-pin one is negative sync. JAMMA boards put out negative composite sync.
I loop the sync signal into both the H and V and it works fine.
