hantarex colors wrong
madmax8
67CR
hi anyone any idea what could cause the following problem with a hantarex mtc9000?
if i use a hantarex us250 power supply with a DC voltage it works perfect but when i use an isolation transformer it gives a strange colored image. The transformer is giving 128Vac spot on.
AaronBoone
165CR
Is your iso supplying the correct voltage for the degauss? I think (emphasis on the think) the MTC9000 uses 128v for the power and then 230v for the degauss.
jengineer
49 (100%)
1,205CR
have you swapped a Polo monitor with a mtc9000? that would cause a colour issue, its the same RGB plug but the red and blue wires have to be swapped over,
madmax8
67CR
ok i rewired all the grounding cables. It works!!
apparently the cheap chinese wiring harnass is not sufficient to power 2 crt's or something like that.
working megatech cabinet now only the pcb
