Hantarex colour controls
Gamelife00
35CR
I recently bought an arcade cab with a Hantarex polo monitor. Just been fiddling with the controls and I've managed to get the contrast/brightness about right. When I turned the brightness up the picture gave off more of a red tint (like it became warmer in colour) .it's not too bad but to compensate I tried to turn the red cut off pot down a bit which helped. When I did this I noticed that the red drive pot wouldn't go any further counter clockwise meaning that the red beam/gun should be off? Or am I wrong here, or maybe it can go a bit further left but I don't want to force it. (Also, the other seperate red 'gain' knob didn't seem to do anything). Cheers
big10p
Coins detected in pocket!
6,093CR
As a guess, it could be the red gain pot is faulty (wiper gone open circuit so has no effect). If not, maybe the red drive transistor is leaky. You could try swapping it with the blue or green one, and see if the problem switches colours. Or just replace the red drive transistor. Like I say, just guessing here...
Gamelife00
35CR
Ok thanks, I have no knowledge with working on CRTs so might just leave it as the neck board looks ok from what I can see, just thought I'd ask first. The red tint isn't that noticeable really
Gamelife00
35CR
Just to confirm, when the neck board is in and you are facing it from the back of the cab the pots are counterclockwise - off/less red and clockwise open/more red)? ...same as how the controls board works with contrast etc? Thanks
paulcan69
946CR
You have two for red
Red gain
And red cut off
Play with both
Carefully as you can get a lick from it
Your supposed to use plastic screwdrivers
Gamelife00
35CR
Thanks, I used one of those pull off plastic knobs to move the pots. The red cut off is all the way counterclockwise and red is still on so I'll just leave it I guess
