Hantarex MTC900 problem
R177
11CR
OK, not too tech savvy so go easy on me please
My Williams Robotron upright has a Hantarex MTC-900 fitted.
When I plug in my cab the screen is blank. However, if I tap the top of the screen once or twice (after removing the front glass) it comes on and stays on. Sounds like a loose connection somewhere or maybe something else?
Can anyone offer any advice as I haven't a clue where to start when it comes to monitors.
thank you
R1772015-10-29 19:41:39
Eddhorse
528CR
More pictures needed of the insides please.
Don't go tapping anything if its a loose connection.
Could be a dangerous loose connection if its to do with the monitor.
Belike
101CR
Or the neck board of the chassis, that is connected to the tube do not connect properly.
Try to push gently through that paper insert when the cab turned off with an isolated screwdiver or something.
tb lilley
5 Star
1,686CR
Agree most likely culprit is dry joint or poorly seated neck card.
As a complete outside option ... I've just had exactly the same fault described. Polo 3 14", would operate in 1 of 3 modes. Either no HV to tube at all (so looks dead); or overly bright picture (volts way too high); or perfect picture. A tap on the side of the cab could produce either result. I was sure it must be dry joint so pulled the chassis and touched up a few suspect looking joints. Made no difference. Reseated neck card, made no difference. But when I had it on the bench I accidentaly nudged the anode wire and screen went from blank to fully working. A bit of experimentation (pushing/pulling anode wire with monitor powered up) suggested a break somewhere in the anode wire coming from LOPT. Removed the wire and replace with one from a scrap chassis. Been working 100% for last couple of days. Never seen a fault like that before. I'd had other problems and had replaced LOPT with a brand new one a few weeks ago - can only think stiffness of anode wire and the way it had been coiled and stuck inside a rubber band had caused a break.
But I wouldn't advise arsing around with anode wire on a live monitor unless you know what you are doing. ....
R177
11CR
I'll take it out my cab and check the plugs etc.
I realise that there is high voltages present. If I leave the cab unplugged for a few days will it be safe to remove it from the cab or will the voltages still be present?
PaulSwan
ZZZ
1,118CR
The 900 has the focus voltage directly off the HV using a bleeder that also drains off the HV. Overnight does it for me.
I'd probably have a tap around with an insulated object first so see I could identify the general area to look further.
Paul.
RSwanson
205CR
Before you remove it, you could try seperately slightly wiggling the video and power cables, at least that would eliminate dry joints on those connectors before you have to remove the whole thing.
If you don't know the history, it's probably best to remove it and check/re-flow every single joint, you'll then have peice of mind that it'll keep going for years to come (unless a component fails).
