Hi all, I've got a Hantarex Polo 20, mounted horizontally, with the following issues:
1. It has the shakes....
Again, at around 4-5 seconds in on this one....
The shaking stops if the V. Amp is reduced so the picture doesn't fill the screen vertically.
2. At interlaced resolutions, if the V. Amp is adjusted so that the picture fills the screen the alternate lines don’t line up unless I adjust the H.Phase to the left a bit, again, turning down the V.Amp fixes this, but then the picture doesn't fill the screen....
3. Adjusting the H. Phase causes weird corruption....
Has anyone seen anything like this before? I've got an identical monitor in another cab that doesn't behave like this, I've swapped the remote boards over and fault remains, so it's nothing to do with the remote board.
