Hantarex Polo 25 - vertical deflection problem
David Fear
3CR
Hi folks
I have a Hantarex Polo 25 with vertical deflection problem / burning resistor
History:
This Hantarex has had multiple repairs.
Here is a list of the repairs that I have done:
[list type=decimal][*]Reflow of cold soldered joints on the main pcb and the neck board.[*]IC1 (LM1203)[*]Replaced the HOT (T114) (BU508A).[*]Complete capacitor replacement except for C107 (the 400V cap).[*]Replaced resistors R167 and R177, along with IC103 (TDA1675A - the vertical deflection IC).[/list type=decimal]
I used: "Hantarex Polo Cap Map & Others" by Keropi, as a guide to replace the capacitors.
I used "Randy Fromm's" polo flowchart as an aid to diagnose the various problems on the hantarex.
I did repairs #1 and #2 and got the monitor working. I sent it back to it's owner, after sending photos and videos of it working. After not very long I was told the monitor was not working again.
I had the monitor back (didn't want it back at the time - family problems).
Did repairs #3 and #4; then, using the flowchart, found I had a vertical deflections fault.
Current problem:
I was diagnosing the vertical deflection problem and found a couple of bad resistors near IC103. R177 was tested at 1R3 ohms, so I replaced it. I think it may have been OK after all as my multimeter may be slightly faulty. R167 tested in the MEG ohm range. I tested both in and out of circuit. R167 is definitely faulty, I replaced R167 with a standard 1/2W 2R7 resistor.
After I replaced the two resistors, I powered on the monitor to test and R167 let out the magic smoke.
Next I replaced IC103 and swapped out the burnt resistor (R167) for a flameproof 1/2W 2R7 resistor.
This evening I powered on the monitor to see if replacing R167 and IC103 have fixed the problem. No such luck, R167 let out the magic smoke for the 2ND time.
QUESTION: What could be causing R167 to burn up?
I have looked at the schematics and I am unsure what is causing the excess current draw through the resistor.
Please help.
David
David Fear2021-05-06 21:57:01
chunksin
21 (100%)
733CR
I had a similar issue with a K7000, although that produces the 25v for the vertical circuit from a flyback winding rather than the power supply, looking at the schematics I would start off by testing D127 out of circuit to make sure it's not shorted
David Fear
3CR
Thanks @Chunksin
I tested D127 as suggested and it found to be OK. When I was testing D127 I noticed something was odd about C139 (the cap next to D127). When I done the recapping of the Hantarex, I somehow must of fitted this cap in the wrong way round.
I replaced C139 cap and the burnt resistor (R167). The cap tested ok, but I replaced it just to make sure.
What this means is: "Fitting the capacitor the wrong way round caused R177 to burn up twice!".
The Hantarex polo 25" is now sorta working (more details here: http://www.ukvac.com/forum/topic383604_post1191327.html#1191327).
David Fear2021-05-12 20:46:10
