Hantarex polo problem
justez
38CR
Hi.
I have a hantarex polo 25, the problem is that when I turn it on cold, for the first ten minutes I have green flashes and interference in the video, and a small buzz in the chassis.
After about ten minutes, it works correctly again.
I attach a video of the problem.
justez
38CR
It could be, I'm going to check the solder joints on the green line, and change the green drive transistor and pot.
Thanx
obcd
3,830CR
In a worst case scenario it could be a short in one of the tube electrodes. I assume running it with the green drive transistor removed is a way to find out if it's the video driver or tube at fault?
justez
38CR
I replaced the green drive transistor and the pot, now it works correctly!
Maybe the drive transistor was wrong, but when it warmed up it worked fine.
Thanks to all for the help!!
