Hantarex polo star keeps blowing HOT
MKL
83CR
TimRose said:
That transistor looks suspicious to me. I have quite a few of them, all pulled from TVs so I know they're authentic, and they don't have that kind of "label" on them. All the markings are engraved on the main body:
Yours looks like the fake ones pointed out here:
http://forums.arcade-museum.com/showthread.php?t=326880
Considering these are used on some WG monitors I totally believe there are a lot of fake ones around esp. on ebay. I hope yours is legit but wouldn't be surprised if it's not.
TimRose
6CR
Holy sh*t I just checked the original ones I removed and they are both flat print as well =/ how do I know if the ones I have a fake or real then?
3,183CR
I'm not so sure, I've got chassis with 2sc5144 the same as that and they were fitted probably many years ago, so unless the!fakes were around years ago (possible) then I'd say it could be authentic.
Judder
992CR
TimRose
6CR
Just had a read of that and I'd does make a half decent read, some good tips. I have emailed randy Fromm last night because I want his big blue book. :)
Judder
992CR
Yes it's pretty good (good old Humphrey!) and I was a bit bored on the ferry to Ireland so read some more good tips below which should also help (I have a couple of monitors I need to fix too so also reading up for that!)
Apparently HOT vary from manufacturer to manufacturer and batch to batch!
http://www.repairfaq.org/sam/deflfaq.htm#dshot
TimRose
6CR
Can i replace a polypropylene cap with a film capacitor? The values are the same and I have seen other monitors with them fitted but is there a difference I'm missing?
TimRose
6CR
I took a gamble with it and it works :) the monitor lives!!! Muhaha. I feel great, what a weight lifted. Thanks guys you have all been top helps.
It's just got one small issue, but if I have to start a new thread just tell me.
I have no keystone, pincushion or horizontal width adjustment. I have horizontal shift, but that's it.
The pictures good it's just stretched out and curved right out. I have tried another e/w board and it's the same so that eliminates that. Anybody had this before?
TimRose
6CR
I've tried the post on the e/w board which shifts the image left and right. That's it, I could adjust the width coil which would make the image smaller but I don't think that's at fault here.
I have removed my controls board extention lead and swapped the controls board itself. None of which cure it. So the fault must be something on the main board.
Sods law that my schematic seems to be missing a strip between the 2 pages which shows you the pincushion circuit.
TimRose
6CR
OK last post of the night, read online about some pincusion correction diodes near the hot and what do you know, one tested 0 volt drop in both forward and reverse diode. So I pinched one from my other chassis and it tested good, now I get this, complete reverse symptom, still no controls but now everything is squished.
Sack this I'm going to bed....
TimRose
6CR
Problem solved, so for anyone else who looses cushion and width control, after changing the diodes right next to the HOT, if you encounter a shrunken screen like above, I found that the resistor right next to the horizontal width coil (r135 I think) was oc, replaced with a spare 10r and problem solved. Hope this helps
