Hantarex US250 TESTING
Steveyp73
11CR
Right chaps, finally getting around to my Chase HQ cabinet. The intermittent power fault appears to be a permanent one now. I've tested with a multimeter but I'm getting odd results. 240v going in no problem, but almost nothing coming out (both monitor and PCB.) I've tested at the Jamma harness too, but again nothing much to speak of (certainly nowhere near 5 volts.) Any ideas? I used the ground points in the cabinet whilst I tested the live sockets - is this correct practice? I'm not an expert with multimeters at all. There must be enough power going through it to light the marquee still. But I'm only reading very minor voltages - less that 1.5.
Georgian2
1,872CR
Black probe on the GND and with the red one test other voltages. Set you multimeter for at least 20V DC range for the lower voltages. Pinout is on that green lable.
Steveyp73
11CR
Well I've just tested and re-tested it. I've even tested all of the fuses on it (which are fine). The monitor power fluctuates from 1.5 down to holding at 0.3. As for the PCB block then nothing at all. Again there is a good 240v being fed into it. I think it's shot tbh. Now the real fun and games start trying to replace it with jamma switch and iso transformer......
2,272CR
I'm just doing the same with a cab, the 250 is just all over the place with voltages. It's a bit of a pain trying to do it without hacking up the loom but I'm sure it's worth the effort in the end.
r-type
633CR
I ended up doing this a couple of years back. Bought lots of cable and molex plugs and did it that way. Now has a JAMMA switcher and an old ISO I had kicking around. Should I ever really want to get the US250 repaired, I can and it would be a straight swap back in.
Steveyp73
11CR
Door switch then yes, that was my first (hopeful) idea - but made no difference.
I'm going to be leaning on you guys (and gals) knowledge once I have all the components in place to replace the 250. To be fair it has been failing for the last 12 mths (randomly blacking out.) It will be nice to have steady voltage going into the thing....Steveyp732022-10-13 16:49:11
Steveyp73
11CR
Right, so as 69er had previoulsy suggested (many thanks) the door switch wasn't properly engaged. I actually have a steady 4.95-4.96v for the board. Which I presume is near enough 5v to be OK. I've tried turning the adjuster dial to maximum setting, but 4.96 is the very best it will output.
However, the monitor output is anything from 1.5v down to 0.3v. Nowhere near outputting 12v. I am presuming that the voltage for the monitor is the brown cable on the attached photo?
Is there another fuse for the monitor alone that I'm not seeing? Or is this thing just dead and gone? In all honesty I'd prefer it if it was just dead, then I can get on with trying to replace the thing with something reliable.....
Steveyp73
11CR
This large and very heavy CHNT ISO transformer arrived today. Does it look correct to you? 200VA. Never bought one before, so don't have a clue really.
Thanks......
Steveyp732022-10-14 14:15:08
Lurch666
21 (100%)
4,518CR
There are four pins on the monitor output of the U250,two are the monitor voltage and two are the deguass.
Are you sure you are not measuring the degauss?
Steveyp73
11CR
Hi, reseated fuse, think it is OK now. Just tested 200v (was on 20v) on multimeter. Getting a reading of 00.8 now and pin next to it is -0.06. Just can't be right.
Steve
