Sorry, I can't think of any good sites that cover it.
The main thing I use the scope for is checking that the voltage levels on a connection are "good" in terms of TTL logic levels.
From wikipedia:
A TTL input signal is defined as "low" when between 0 V and 0.8 V with respect to the ground terminal, and "high" when between 2 V and V[sub]CC[/sub] (5 V), and if a voltage signal ranging between 0.8 V and 2.0 V is sent into the input of a TTL gate, there is no certain response from the gate and therefore it is considered "uncertain" (precise logic levels vary slightly between sub-types and by temperature). TTL outputs are typically restricted to narrower limits of between 0.0 V and 0.4 V for a "low" and between 2.4 V and V[sub]CC[/sub] for a "high", providing at least 0.4 V of noise immunity.
So if you scope a signal and when it's "low" it's at around 0.8V I'd be worried that some gates would consider it low and others would not.
Some manuals (I'm familiar mostly with Atari stuff) will also give you example traces of what a "good" signal should look like at certain test points - this can be very useful when fault finding.
If the scope has a "measure" feature (my Hantek USB jobby does) that can be helpful for checking things like clock frequency and the frequency of signals divided down from the clock as well (on the USB one you can just highlight from 1 peak to the next on the display and it tells you the time/frequency)
