Hanterax tubes /chassis
urbanledge
95CR
I've giving a fella a 19/20" hantarex with a busted 900e chassis (110v)
I'm going to sugest to him he finds another 240v chassis.prob a polo.
Are the yokes the same on all the hanterax tubes?
tb2000
3,578CR
Yep, Polo 1 20" chassis will fit no problem as long as the neck sockets are he same - some of the older 900/E's used a different type, bit like a 'ball and socket' design.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
from what I understand I think you can do a socket swap to make the chassis work
tb2000
3,578CR
You can indeed but I only really do it if it's already somewhat loose. Some of them seem to be stuck incredibly well so I leave them on for fear of damaging the neck!
obcd
3,830CR
Isn't hantarex glueing the deflection coil and the tube together after they adjusted everything at the factory, assuming picture tube and deflection coil staying together for the rest of their lifetime?
tb2000
3,578CR
It wasn't Hantarex themselves that glued them on but Videocolor who made one of the range of tubes that Hantarex used. They're difficult but not impossible to get off. Orion for example (another widely used tube by Hantarex) just had a standard non-glued yoke like most other tube manufacturers.
tb20002014-08-27 10:28:53
236CR
This is actually a MTC9000 chassis and its an Orion tube, chassis isn't working so will probably upgrade to a Polo chassis as I'd like to drop the iso tranny as well.
Are these expensive anyone doing a part-ex against a dodgy 9000 chassis ?
tb2000
3,578CR
Polo 1 20" will be more expensive than 9000. I may have one but there's been a number of people looking for these i'm in contact with so may have run out. If I have one i'd be willing to do a part-ex on a 9000.
