Hanterex MTC9000 sync issue
Paul_in_nottingham
160CR
I've got an Hanty 9000 that I cannot get a steady picture on.
Previous faults have been fixed, I've given it a cap kit, HOT and LOPT, so all the common things have been done.
It used to have a steady picture but refused to extend onto the top inch of the screen. This seems better, but I cannot get it to hold , it just rolls.
I suspected the adjustment board as some of the pots felt gritty; however swapping it with one off one of my 9110s has the same fault, in fact the adjustment board works fine on the 9110, after swapping them over.
The colours are nice and bright and the tube is burn free, so really want to get it working.
Any ideas what the issue might be? Paul_in_nottingham2014-03-09 21:36:16
RaveN
1,325CR
When you were working on the chassis, is it possible you knocked the sync polarity switch (near the green video connector?
For Jamma it obviously needs to be negative sync and the switch should be set so that it is closest to the video connector.
It's quite easy to knock this, and if it is set to positive sync you will find that the image rolls and you can never quite get a stable picture.
Paul_in_nottingham
160CR
Tried that now, it's still rolling.
tried with switch in both positions.
Any further ideas?
Paul_in_nottingham
160CR
SCI. It only has one sync output. Just tested continuity from the board to the monitor, both V & H using the link wire suggested by Ordyne. Tests fine, despite at some point the normal connector having bean replaced by wires with molex pins on them.
Strangely, the original monitor (a 900e) was serviced by Ordyne in 2011 before I took possession of the cab. This monitor still needs fixing after its Hanty PSU fried it..
Gunblade - mainly vertical with a slow track to the side. Rolls horizontal if I flick the switch.
Cheers for your help guys.
RGP
Meeter & Greeter
2,039CR
At this point i'd be having a look at the sync circuit - I say this because I had the exact same kind of issue a few months ago on a WG-V1001 (B&W) monitor and it turned out to be the two transistors in the sync amplifier.
Craig or Grant might may have a better suggestion though.
Paul_in_nottingham
160CR
Thanks James. Never had to look at a sync circuit before.
Any idea what components this is on a 9000?
EDIT - Just followed the schematic - I'm in uncharted water but I reckon I should pull and test the following transistors, TR10, TR11, TR12, TR13(maybe) - is it likely to be the IC that's after them in the circuit?
Any advise appreciated.
Paul_in_nottingham2014-03-11 15:01:37
RGP
Meeter & Greeter
2,039CR
Here's the manual with schematic at the end.
http://arcarc.xmission.com/PDF_Monitors/Hantarex%20MTC9000%2014in%2016in%2020in%20Manual.pdf
The sync circuit is on the first of the 2 schematic pages find the "H.SYNC" and "V.SYNC" pins and follow them and you'll see SW4 is the first thing in line, one of the SYNC's will go to C20 and the other to C18 - ultimately both circuits meet at TP5 which is then fed into the TDA2595.
Do check you have a stable +12v at TP12 as this powers the TDA2595 chip which the sync feeds into.
Again, in my own experience, it was 2 transistors which under regular test on a multimeter looked fine but on observing their actual behaviour on an oscilloscope I could see (as instructed) that it wasn't doing its job properly anymore.
Depending on what tools you have you might be able to sort this out. If in any doubt, send it off.
I will throw in the standard warnings about poking around with monitors while they are switched on both for your own safety and not creating additional issues by shorting components out accidentally.
Paul_in_nottingham
160CR
Thanks for your help James - hopefully get to look at this before the weekend now the evening are getting lighter.
I don't have a scope, although I'll test the transistors on my MM, for the sake of a few pence I may swap them out anyway.
Paul_in_nottingham
160CR
Ok guys, so swapped out TR10, 11, 12, & 13, along with TDA2595. Also tested the caps in the sync circuit and they seem fine.
Unfortunately, it's still the same. Any more suggestions of where to look?
RGP
Meeter & Greeter
2,039CR
Ordyne said:
TDA1675 would be where I would be looking at not TDA2595
Craig, are you talking about IC1 or IC2? Or have we (me and Paul) been looking at wrong schematic, is the 1675 a suitable alternative for 1670 (not looked at datasheets).
I hadn't followed the node going up to IC1 and had rushed reading forward into pin 9 of IC2 looking for a horizontal sync.
Ignore my ramblings :)
If it was in front of me with a scope I would have figured it out within a few mins.
