Hantrex 9000 problem
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have a jamma cab with a Hantrex 9000 chassis.
Cab shows a white picture but nothing else. Game plays and sound. I have even tried the monitor in another cab but still the same.
Remote board is connected also.
Any idea's what could be wrong and if it's an easy fix? Shall i try a cap kit or could i be wasting my time?
Steve2014-08-10 14:12:48
bonehead
50 (100%)
1,729CR
Could it be worth swopping another kneck board or could there be a particular component at fault?
Sorry for all the questions but I need to get some cabs fixed before I drown in non working stuff!!!
singy1uk
119CR
Looks like shorted drive transistors on the neck card.if its a white screen indicates all guns are open.test the resistors on the neck card.its also possible the brightness pot is shorted that could cause the same symptoms.
Ordyne
1,282CR
Looks like low video b+, I wouldn't be looking at anything on the neck board yet apart from measuring the video b+ at any of the 3 large transistors on there. Looks like your voltage may be pretty low.
Can you check this and report back?
bonehead
50 (100%)
1,729CR
Hi a quick update.
Measured b+ and got 128.8v
Tried adjusting by only get 128.5 to 128.9
Where do I go from here please?
Thanks,
Steve
gunblade
9,121CR
the only pointer i will give you is pin 9 flyback,consult the schematic and then you will see exactly what Craig is talking about
he basically told you how to fix this
Ordyne
1,282CR
There's nothing on the lopt going to the degauss!
Your confusing video b+ with b+, they aren't the same. Not sure how you were adjusting the b+ on an mtc9000b!?
I'll look at some schematics when I get to work as it's been a good couple of years since I picked a 9000 up.
Ordyne
1,282CR
As grant said you want to be looking at pin 9 of the lopt, your looking for 190v at TP14, you could also check this at the 3 large transistors on the neck board or C205 on the neck board. This is the video B+ which is different to B+
If you've got a really low reading then you could test R126 and see if you have the 190v at D15, if you don't then you've probably got a bad lopt, if you have 190v and D15 / R126 is good then you most likely have a crack in the chassis / neck board or a broken wire at SP11. You could also check for cracks in the track of pin 9 of the lopt!
Measure the voltage first tho!
