Hantrex 9000
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Can a hantrex 9000 be powered by a 120v or does it need 240 and degause 110?
Might have to replace a hantrex 900e USA chasis for a 9000.
gunblade
9,144CR
usa 9000 run on 120vac
Europe 9000 run on 120vac and 240vac is used for the degauss circuit
you can wire up a Europe 9000 to run on 120vac only as I have done this in the past
gunblade
9,144CR
bonehead said:
Ok thanks.
Don’t suppose you have a 900e USA chasiss working there do you?
Also do you fix Dino king monitors?
no they are pretty rare and tbh I would recommend fitting a 9000 in any case
I can only fix dino king if I get the entire monitor as I don't have anything even remotely similar tube/deflection yoke wise
bonehead
50 (100%)
1,729CR
Ok thanks for the reply.
Would you know if I can fit a 9000 chassis on the 900e tube if he neck size is the same? I ask as the tune has heavy burn for gauntlet so would make sense to use the same tube.
STEVE
