Hantrex mtc 900
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I have a gauntlet cab with a hantrex 900 chassis that’s faulty.
Can I replace it with a 9000? Wasn’t sure if the yoke windings are the same.
Also is it worth fixing or just replace with another monitor running a 9000 chassis?
tb2000
3,579CR
Is it definitely a 900 or do you mean a 900/E? Either way, as long as the neckboard has the correct connector you should be fine putting a 9000 on it.
BarrySlisk
162CR
The MTC9000 is mechanically and electrically interchangeable with earlier Hantarex monitors MTC 900 and MTC 900E with respect to input signal, input power, deflection connections and fixing points. The CRT socket may need to be changed.
http://www.swallowam.co.uk/monitor.php
...and if the MTC-900 or MTC-900E had east-west correction then you need to
get and fit an east-west correction board for the MTC-9000 chassis.
