Happ force feedback motor.
SassMate
77CR
Anyone got one of these they can take a picture of for me please?
Its the force feedback motor from a need for speed cabinet.
This one is missing the grub screw that holds the splined rotor on which the belt runs over.
The splined rotor is very loose on the motor shaft which has got me wondering if it should have some sort of collar inside it.
69er
1,730CR
It’s a common issue on need for speed feedback motors .. I have replaced several belts and drilled through a splined spigot and motor shaft before to fit a nut and bolt through…. The splined pulleys can be bought but can’t just recall where? As long as the motor spindle is not worn down at all . The splined bobbin is only alloy and wears quickly due to the aggressive motor action steel shaft.
Just remembered “Simply Bearings” splined pulley specify pitch width diameter and hole bore ….
SassMate
77CR
Many thanks.
Drill and bolt is high on my list of possible fixes, I was concerned about the alloy rotor not turning true on the shaft due to it being off center.
Ill take a look at simply bearings. Thanks again.
