Hard Drivin'
paulcan69
945CR
Ok here's something to get your teeth into...
(I know how to pick em' - LOL)
You lot get bored with the newer stuff....thought you'd like a bit of this, 1988 and all that!
Atari Hard drivin "compact" or upright with a seat..LOL
What I have learnt,
The sit down version is med res (And has an electromechanical seat)
The upright is standard "low" res
The pcb can output both med res and low, but there are hardware differences but only like extra pcbs for seat and a more complex gear shifter
My monitor is fine, my pcbs run and boot
I can play a game steering pot makes the car move (Plus all pedals etc...are good)
Only bad points
No sound - amp is running can hear hum noise through the speakers
No force feedback
Looking at force feedback motor pcb I found 2x blown fuse (It only has 2 fuses on it) Replaced them both for slow blow 4amp as in the schems
....And pop!!! the second I turn the cab on, both blow again
Your thoughts please? - Steering wheel does move ok, and turns the motor ok - i.e it's not seized
Sound is weird, you can hear the hum, but no games sounds at all
But if you go in the test menu and run a full test there is a sound board check which does produce some "basic ass" beeps and slight basic tune
I'm thinking 2x separate faults, motor/motor amp pcb
+ maybe bad sound rom or roms?
Or short in loom?
Any ideas warmly welcome, just would like how you would approach it, or if you've played about with one and had anything like this?
I need to measure the ohms of the motor as I read today between 6 and 20 ohms is ok
I'm sure I got 40 ohms last night when looking (Need to re-check)
Many thanks,
Paul
BristolMartin
0 (50%)
382CR
I own a lot of the HD cabs and I don't wast my time as a PCB stack can be found for about £50.
Yes you are correct Sitdown and upright are different satcks and Jed said never to mix them.
karlcdoe
887CR
Or short in loom?
First up: I know nothing specific of Hard Drivin' but at a very quick glance I guess it's too 'new' to be the standard sys1/2 arrangement of 6502 + ram + pokeys + ym2151, etc. However I did stumble across a page form the past by the man himself so worth a look even if it's an unmaintained page....
http://www.jmargolin.com/schem/schems.htm#dsb
paulcan69
945CR
@bristolmartin I mean the motor not the monitor
@karl - Cheers bud
Had a brainwave today
I unplugged the motor and it still blew the steering
So to me ruled out the motor does it not?
Need a bit of help testing this motor pcb
paulcan69
945CR
Ok so pulled the motor amp pcb out
Whilst still in circuit I probed one of the mosfets
http://www.vishay.com/docs/91031/sihf630p.pdf
It showed continuity across all 3 legs?
Is that correct or does it show it's blown?
paulcan69
945CR
Anyway scratch that
I metered the 3 power? Wires coming into the motor pcb (if that's what they are power)
And it showed continuity between them
Wtf?
Should these be connected together
They all come from the main transformer
They are grey, grey/white and grey again
Can anyone confirm on their cab is this normal
Looking at the schemes I can't work this out?
Please?
