help, 60 in 1 joypad problem
donks49
3CR
Hi Guys
please can somebody help a beginner.
I have a cabinet which had a game elf 412 installed (horizontal)
i have bought a 60 in 1 from Frothmeister and installed this evening i get games appear on screen and sound but buttons and joysticks dont work, can anyone help please
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
you need to credit the board before the joystick becomes usable
or then set the 60in1 to FREE PLAY
that way pressing the start button once will allow the joystick to move and pressing it a second time on the game will start the game
frothmeister
58 (100%)
947CR
Does your machine accept coins? If so then insert a coin to get a credit.
There is a TEST mode though that you can use to change it to freeplay mode. There is a little bank of dipswitches (blue) on the top of the board.
You need to switch one of these to the ON position - iirc it is number 4 (while the machine is powered off). Number 2 should already be switched to ON, as this is for switching between a standard 15khz arcade monitor and a VGA monitor.
When you power the machine up again then you can go into the TEST mode and change settings for the games/put it in freeplay mode if required/test all controls etc etc.
Once you have changed whatever settings you want to change, you must press either p1 or p2 START to save these changes or they will be lost when you power it off again.
Once you do power it off again, flick the dipswitch number 4 back to the OFF position and when you power it up again the changes should be effective.
You want to put switch number 3 to the ON position as well - as this turns on the high score save feature.
frothmeister2016-07-15 21:39:13
donks49
3CR
bingo! thanks mr frothmeister, all sorted screen changed all working, one happy dad and three mega happy retro mad kids! you are a star, thanks a million!
i was surprised how easy it was to change screen around, one thing that does worry me is the cable from volume switch inside front door that has a 3.5mm jack on the end gets extremely hot, is that right?
big10p
Coins detected in pocket!
6,093CR
No, that doesn't sound right - although I don't quite understand what you mean. Can you take a pic?
