HELP: Chihiro NETBOOT info
Sbdesign
SEGA collector
16 (100%)
1,723CR
Hi Guys,
I got a virtua cop 3 Deluxe cheap that was in need of repair.
Chihiro = BAD
GUN 2 = SMASHED
I recently got a Standard fully working VIRTUA COP 3.
The idea is to swap the parts and make the Deluxe work, and perhaps use the standard to make a Naomi Joystick Arcade (but unsure as I have 1 triforce and 2 x Naomi versions already)
FOR NOW:
I want to get net booting working as it is on the standard version (so forget all the above)
I HAVE:
A naomi with piforce.
FOR TESTING:
Can I just add the Chihiro ROMS to the same SD CARD? can I then simply put this net dim in the CHIHIRO and boot?
Im guessing not that simple. Links to a guide would be good.
Currently the GDROM takes for ever to boot, and I wanted to test the house of the dead 3 as well as quicker VC3.
penrhos
747CR
I think the data file you need is available on AP. if its the same PIC chip as for Naomi I can burn them with my TL866CS cheapo eprom programmer.
Sbdesign
SEGA collector
16 (100%)
1,723CR
Brilliant thanks for the offer..
see if anyone knows if it is or not?
Does anyone reading this know if the pic is the same chip as naomi?
big10p
Coins detected in pocket!
6,093CR
I think the PIC you need depends on the type/version of Chihiro you have. I get my Naomi PICs from Jelacooma so might be worth messaging him to see if he does PICs for Chihiro.
