help chihiro type 1 netboot
8,292CR
im loading all games ok
 but after title intros  game quites out to chihiro screen
error message 33  gatway not found ?
 there is  network settings for  media board & network settings for core..
 so im settign the same ip adress 192.168.   1   2
 defult gateway 255 255 255  0 ?
  same on core   im setting ip address  as same   ?
  also subnetmask as gateway  ?
any help appretiated...
Like do I need to set the core network settings?
512 mb chihiro
512 mb game files. Retroman8392021-01-13 15:57:54
chunksin
21 (100%)
733CR
Do you have a null security pic chip installed in the netdimm? depending on which version of the piforcetools you are running you might need one. Certainly sounds like the usual security chip timeout though.Chunksin2021-01-13 16:06:02
chunksin
21 (100%)
733CR
Naomi zero pic is fine to use, (shameless plug) if you use my image and enable the time hack mode you won't need a pic chip as long as you keep the Pi powered on and connected. It works over WiFi so you need a Pi 3B or Pi4 but you can also use the older LCD screen if you have one.
Download link is here: http://www.ukvac.com/forum/topic378472.html
8,292CR
That’s cool
So is that an image of the pi loader /pi force tools?
Would be cool no to need a pic as I can keep the pic in the
Naomi then..
Got zero pic in and all good thank you
But yeh I will use your image as I plan
On putting another pi 3/4. Together ..
sound pretty
Cool not to need the pic:.. a good hack if ever there was!
Do you know ? While i got your here...
Will sega gun io. Type from house of the dead 2 ( common sega type )
Work with Virtua cop3
Hotd 3
Ghost squad ?
Shamelessly trying to not have to get it all out wire it all up
And it not be the correct set up...
I have hotd3 io and shotgun but I’m missing the small pcb the links the guns to the io...
But I have a complet hotd2. Slightly older io type..
this type working but don’t have the peddle / duck button
needs to be added
also pump action button needs adding to loom Retroman8392021-01-13 17:13:19
145CR
Virtua Cop 3, The House Of The Dead 2,3,4 and Ghost Squad all use the same gun hardware (a type 2 gun board into a normal JVS IO) - so it should work just fine.
The triggers are generally all on the same IO input, however things like the screen-out, reload, special buttons may need to be swapped about in your loom!
