Help identifying please?
11CR
Hi,
Can anyone help identifying these two fellas? (and if there is anywhere to get some)
Marked as - 5E 222J Fu 415 & 5E 511J Fu 491
They are on my Bombjack board & I fried them sending power to board. (picture is from my bootleg Bombjack).
Also Bombjack - my backgrounds keep dropping in and out, If i push all the chips on the board it sorts this (for a while). Is there a certain number chip I should be concentrating on?
69er
1,834CR
Look like 5 pin commoned resistor array package . just save tracks and separate resistors can be found on eBay or older component dealers or on donor pcbs that don’t function
Background issue if subject to pressure likely plug in chip poor contact or if it’s twin board probably the edge connect ribbon or perhaps dry solder joint or minuscule crack in a track near to a solder pad or ‘through hole’ position lots of reasons even heat????? Or warped pcb at that age
