Help identifying this plug
bones
1,628CR
Hi, any idea what this plug is called, it's from a digital juke box and connects into the touch screen. It's the same as the ones you find in Sega GD roms and it's tiny, 8mm long and 2mm ish wide, got a damn wire broken off and my soldering iron tip is 5 times bigger than the crimp lol. Help !!!!!!!
FrancoB
1,040CR
It looks to be JST PH series.
The data sheet [here] says the PHR-5 five pin one like you have above is 8mm long.
They are tiny contacts. I used to make Atomiswave stereo cables which used PH series. They do crimp ok with the Hozan P706 though.
Edit: RS Components have the housings in stock [here] (MOQ 10) and the contacts are [here]. MOQ for the contacts is 250 but they are only £0.022 each.
ArcadePCB
509CR
I'm not sure - but it maybe a Molex connector. That JST PH series seems to be higher than the one you've posted. Maybe Molex Series 53398.
