Help : Mr do's castle problems.
penrhos
747CR
I have two problems.
1) game won't coin up - works on free play.
2) monster graphics are corrupt, when moving around and when dropped.
I'm going to pull the roms and compare them to MAME to check for corruption and other suggestions?
big10p
Coins detected in pocket!
6,086CR
The Mr Do! games have weird wiring on the coin switch. I forget what exactly, but it's in the manual. My Do Run Run was the same so had to have it on free play.
RGP
Meeter & Greeter
2,039CR
Can't help you on the coin up side, all my games are on free play mode too - I tend to stick clear of the coin mech side.
On point 2 either bad EEPROM or bad selecting of the EEPROM with the graphics in if some graphics are fine and then other animation cells are fine.
Try lifting all the EEPROMs out, cleaning the legs and reseating at first, if you have a logic probe see if the select lines are toggling on all of them - they should do at some point.
A video would help of the problem if you can :)
big10p
6,086CR
Here's how the coin switch needs to be connected, from the Do Run Run manual. Pretty sure it's the same for all Mr Do! games.
RGP
Meeter & Greeter
2,039CR
If i have this right, essentially the board is waiting for a HI to LO transition instead of LO to HI.
+5v is going to the NC (Normally Closed) side of the switch and the GND is going to the NO (Normally Open) side and the GND of the switch is going to the coin input pin (24 for left coin switch).
So the pin 24 is always receiving +5v and the board sees a HI state - when you press the switch, NC opens and NO closes connecting pin 24 to the GND point ("B") and creates a LO state for the board.
I've seen this type of thing on a few other games like Star Castle and Carnival.
penrhos
747CR
Same JAMMA adapter works fine with my Mr Do PCB and coins up?
Don't suppose anyone knows which eprom holds the character data?
When I get home tonight I'll pop em all in the S4 and compare them to the ones from MAME.
penrhos
747CR
Right after reading all the roms and verifying what My PCB had installed it looks like the PCB I have is Mr Do's Castle V1.
I compared the roms I have against MAME's Oldver, V1 & V2 and all but A3 & A9 Verified OK against the V1 set. A3 had bad corrosion on the legs and as I had a few TMS2764's in the spares box I'm going to swap the three roms over for the V1 equivalents and see what happens.
A9 looks like the culprit for the corrupt monsters.
penrhos2016-01-14 22:53:27
