Help : MW RT-85A PSU issues.
penrhos
747CR
I've got a MW RT-85A PSU it does +5, +12 -5 and is about the same size as the one used in Boardmaster/Pana/Vega Superguns.
It's brand new - but I've lost the paperwork so can't return it...
The problem I have is that the PSU keeps shutting down
The power LED pulses and the voltages keep doing the same as if it's going into some form of short-circuit/overload protection. I've tried the obvious:-
Mains connection only - same result.
Mains and +5V to dummy load (some 5V lights) same result.
It's outputting +5.12, +11.95 -4.8 between shutdowns.
penrhos
747CR
Think I've sussed this - reading the datasheet it needs load on +5V and +12V lines or it goes into shutdown mode...
That seems to be a bit odd as several sites state the Sanwa SWN-7E is this psu rebadged and that works fine with no load on it...
I'll check if I have a Sanwa one and compare the values of some components.
