help needed
kielmj20
6CR
Hi fairly new to this but need desperate help with my cocktail cab i have three cocktail cabs hoping to make one good one but i don't no were to start with making on work. can anyone give me a heads up on this any questions please ask away and ill tell you all i can about my problems im having thanks guys
cosine
14 (100%)
595CR
What are the cocktail cabs? What are the faults?
The biggest problem, assuming they're 80s cocktails is the wiring will probably be unique to whatever game it's running, so you really need to figure out what you want to do with the worker..
kielmj20
6CR
Right now I've got two mins to sit down and tell people. i firstly bought a taito cocktail it turned on the picture came on but it was white and then faded to just a white screen but can still hear the game playing the connector to the board has been removed and soldered straight to the board the second one i bought was just for the legs but got game board and it turned on justice fan with no sound or screen came on the third on was just a cheap purchase everything is there and does the same as the second. i have game boards but not sure if any of them.are any good is there anything i can do to see what game boards work and what doesn't i want to keep one original instead of gutting it and sticking a pc in it i really don't want to do this as you can see I've got my hands full i just need to no were to start but one is a phoenix other than that the game boards don't give me any idea what they are the other cabs are original and nothing has been cut so important guessing the games are to the cabs im really stuck I've got lots of spares just need a kick start. please help or shine a lightht ive seen people offering to fix broken arcades but its so expensive and no were near sheffield can i send my boards somewhere to get tested to tell me what's good and what's not i do no a little about em but so don't.be scared if you think you will blow my mind sorry to go on and on I've been pointed to this site you are the people to know please help
Paul_in_nottingham
160CR
Welcome to the forum dude.
First of all, to allow people to help you better, if you haven't got one already your gonna need a digital multi-meter. Don't have to spend the earth, you won't need top of the range one, or even a mid range one at this stage; you should be able to get one for under a tenner that'll do the job.
Secondly - pictures paint a thousand words. From what you've described, each machine could be a massive number of things wrong, or something very simple.
Thirdly - Paragraphs help when describing faults.
Try and keep it concise.
Start by posting pictures of what you've got, including the boards and tell us which shell you wish to use as your final cab. that way people can advise what needs taking out of it / putting into it etc...
kielmj20
6CR
Hi i took some pictures of what im getting on my tabletop can anyone help there is no.sound or picture just a white screen when i turn it on
kielmj20
6CR
With me not having a machine that works i couldn't.no if they do but the one in the picture is like new to look at but from what I've read about pcb they can be funny little things. does anyone no how i could test them or get them tested all i want.to.no is if they work ?
Purity
The Oracle
17 (100%)
2,999CR
You may have a test rig setup. The best option might be to run the PCB using a supergun if possible, but you would need to know what the pinout of the board is.
Might be worth while taking some photos of the PCB's so we can work out what they are. From there we would then know the pinouts
Purity2014-03-12 12:56:02
kielmj20
6CR
Can anyone tell.me what this is. since i last posted i found a fuse that had blown and the little bulbs only had the yellow one on when i changed the fuse the game sprang to life with both the red and yellow bulb lighting up only for a short while then back to the yellow bulb then nothing was coming on i changed the fuse and still nothing only the yellow bulb but both fuses are fine any help please
kielmj202014-03-14 10:12:57
Purity
The Oracle
17 (100%)
2,999CR
I am not familiar with Taito Cocktails, however I'd guess that the board you are pointing at is some kind of power regulator? I'd be trying to check what power is going to the PCB, to see if that looks correct or not with a multimeter. You would need to work out what the power pins are, at the pcb
So exactly what Paul in Nottingham said
Purity2014-03-14 11:50:09
kielmj20
6CR
Thanks.for that this cab isn't the taito cab its looks like a aftermarket. one with a phoenix game.inside the game fired up for about a.minute then back off so im guessing the voltages are fine to the board cos it all worked but the fuse is fine but nothing is happening.now might just take.it.to an expert does anyone recommend anyone in the sheffield area or as near as possible
Purity
The Oracle
17 (100%)
2,999CR
I think you are missing the point. If the game fired up for a minute then it may mean the voltages were fine for that minute, but then they weren't as the game died. Without looking at the voltages at the PCB you don't know if this is a power issue or PCB issue
Also because you had a blown fuse on that board, it would indicate it has a problem somewhere, even though it has not blown the fuse the second time.
Did you change the fuse for a like for like? Do you know that the fuse is the correct value
Purity2014-03-14 11:58:14
kielmj20
6CR
Hi again when the red bulb is not lit there is no power going to the board and now I've put a new fuse in not even the red bulb lights up only the yellow.one stays on thanks for being.so.patient with me i am really new to this thanks again for all your help i really appreciate it
