Help please....
G
Guests
Guest
Can't seem to find a 875 ohms resistor anywhere. There are tons on eBay but none for that value.
G
Guests
Guest
I'm a little new to these things, will having a slightly lower or high resistance have any effect?
Would i be better off going for a higher resistance or lower?
Battlezone
410CR
The pull down resistor between the ground (black) wire and the sync (white) [I can't quite see in the photo if it's "H" or "V" or "C" sync - I'll guess H] will shift (reduce) the high voltage level for the sync signal coming from the PCB.
The resistor will reduce the swing and will sharpen up the falling (active) edges and slow down the rising (trailing) edges slightly.
Maybe the monitor is fussy about the exact shape of the sync or maybe prefers something slightly less
than a +5V logic level on it.
All this would impact the timing and blanking of the horizontal lines, I'm not really sure why it would impact the brightness or transparency of the dots (unless they are happening during flyback).
Battlezone2016-04-08 13:51:02
5,325CR
Can you let me know how loud the replacement fan is?
My Crisis Zone had a knacked fan so I 'acquired' one from a bin at work and it's like a vacuum cleaner, so I'm interested to know how loud the original fan is.
Although saying that, was it bodged with splice clips because someone had put an alternative fan in there?
I do wonder if the bad textures was due to a ropey connection - if it was that heat sensitive, you'd think they'd at least heatsink critical components.
G
Guests
Guest
It's been awhile since I've posted as I've been really busy and the time i have had for the machine has been rather stressful. I've got the pedals working now and the machine is fully working. I just have some strange white dots on the screen which I'm working to fix.
Still working on fixing this. I also noticed the rear exhaust fan was completely dead and upon taking it off it's mountings the fan fell to pieces! I've ordered a new one for it.
I also got my gear shift decal from Muddymusic
Need to get that fitted soon.
Overall though, its working ok just afew niggles to sort out.
rotunda2016-04-11 12:15:09
