Help wiring a UHID
eoinzy
11CR
Hi,
I have a 2 player driver cab and I bought 2 Ultimarc U-HIDs with the idea of converting to a MAME driver.
Its a Battle Gear 3 cab, running on System 246, and has the gameboard, a JVS I/O board and the audio board.
To be honest, this is my first foray into arcade cabs and electronics so I'm looking for a guide on how to wire up the U-HID to my specific arcade. For example, can I wire the controls into any pins on the uhid and configure which is which in software?
Can someone tell me what parts of the steering wheel and pedals I need to connect to the U-HID? Do I need to start snipping wires, or can I reuse the same connections somehow, for easily swapping between MAME and stock (if I ever get it working again!)?
I already have 2 PCs with R9 380X for output via DVI-I to the CRT.
Thanks.
Brettster
1,292CR
I've not used a Uhid but I have wired a cab up with A pac, J Pacs before and I guess its pretty similar
basically your cab is JVS so it wont be used with mame, unless you can connect a JVSpac 2 to your setup?
otherwise to use a Uhid it will be a case of connecting the pots from the wheel and pedals direct to the Uhid and butchering the factory looms, unless you can make your own looms with the right connectors and make it reversible
more wires will be needed for the gear stick and once you have them all connected to the Uhid, windows will see it as a bunch of controller inputs which you can then map to your games you want to play.
If a JVS pac 2 can be used then you wont need to do any wiring, just plug it into the JVS IO board and then into your PC.
each Cab will be different to wire up and you might be the first to do your cab with a Uhid
some details on the untimarc website for what pins do what
https://www.ultimarc.com/control-interfaces/u-hid-en/u-hid/
eoinzy
11CR
Oh, I wasn't aware the JVS-PAC even existed!
So you're saying I can just get a JVS-PAC 2, connect one end via USB to my emulator PC, and then simply disconnect the existing loom that is connected to my JVS I/O board and plug it directly into the JVS-PAC, and thats it done? No snipping wires, no soldering, no butchering the factory looms or anything else?
If its as simple as that, then I reckon that'll be the best option, obviously!
Brettster
1,292CR
The JVS pac2 will plug into your IO board instead of the original arcade game board using the USB cable.
so yes no re wiring etc plug and play.
but I don't know if it supports wheels and pedals
best bet will be to ask the creator of the device Invzim before you buy one. For normal stick type cabs it will show up as 2 keyboards or controllers in windows.
Edit
https://irkenlabs.com/jvs-pac2/known-issues-faq
Well I looked a little further on the page and it says it does not support analogue cabinet controls yet, but worth asking him as on forums he's said it has more features than what it lists on the site
Brettster2020-05-30 17:37:14
invzim
24CR
It doesn't support the analog stuff you need for a racing cab, yet - but it's on my TODO list.
If I had a racing cab (and the space for it), it would likely have been implemented ages ago.
Currently the JVS-PAC 2 shows up as a keyboard, 2 gamepads and a mouse - but only JVS is currently routed only to the keyboard.
eoinzy
11CR
OK thats a pity.
Thanks for the reply guys, and for the clarification invzim.
BTW, if you were to implement the "analog stuff" for the racing cab, is that something that would come in a software/firmware update, or would it need a hardware update to the JVS-PAC 2?
eoinzy
11CR
OK cool. Definitely a board I'll get when thats available.
In the mean time, I'll have to figure out how to wire the controls into the U-HID!
eoinzy2020-05-30 19:30:18
