Help wiring cab.
1980-20..
20CR
Can anyone help with wiring mains power into my jamma cabinet. I've had a look around online but can't find any info.
I striped out the old wiring a few years ago in preparation of replacing it and took photos of how it was wired. I have since lost the photos and I'm sure I've lost some components as well.
Any help much appreciated.
Venom
818CR
TBH i ended up replacing both power supplies in my cabinets although it depends on your monitor too if that was being powered as well. Has that got any power too it ? As retro said post some piccies up.
Some old power supplies can be pretty crappy and not give enough to some stuff,
Venom2021-01-10 23:32:57
1980-20..
20CR
Will try and get some pics up later. I've got a switching PSU in the cab and jamma harness is connected up. Need to know how to split power coming in between PSU monitor and marque.Oh and wiring in the door switches.
1980-20..
20CR
Ok pictures. This is the power coming into the cab.
This is the cable coming from the monitor.
Switching power supply.
8,290CR
http://arcadecontrols.com/BBBB/acwiring.html
All looks good but you can have an isolation transformer
240-240 in line to the monitor
That will prevent your monitor frying everything if it decided to melt down. Retroman8392021-01-14 18:35:08
1980-20..
20CR
Cheers for the diagram and the information. Any ideas where I'd get an isolation transformer from. Also the diagram lists a power distribution block any info on that as well.
Ta.
Funhouse71
1,084CR
You can made a distribution block for all the AC power in different ways, one suggestion for the distribution block is to use barrier strip terminal that can be screwed to the bottom of the cab.
http://uk.rs-online.com/web/p/barrier-strips/7821930/
You could then get some jumper strip (2nd) link below to join up to 4 terminals together to make 4 Neutral and 4 Live terminals on one side of the strip with 2 spare terminals for the earths. Crimp some fork terminals on the wires of the Light / Monitor Transformer and Switching power supply Live/Neutral and earth wires.
http://uk.rs-online.com/web/p/din-rail-terminal-accessories/3910225/
Now attach the Live/Neutral and earth wires to their respective terminals on the other side of the barrier strip.
Funhouse712021-01-14 23:00:39
8,290CR
if high voltage traveld down the power chord ?
i believe the scenario is the high voltage leaks , arch’s , jumps , shorts, across to part of the chassis because of
breakdown of another part of the chassi,
then that high voltage electricity is on a new path which could include
travelling down the power chord connected to switch mode through the terminal block.
then the high voltage travels up the 5v 12v result 1 fried game pcb.
i have just used a separate chord plug before my self for 240v polo. plugged into a different wall outlet
completely separating the circuits but it’s messy having two plugs..
iso transformer is to protect the rest of the circuit from high voltage overload.
i believe the reversed electro magnetic field created on the opposite side of the transformer stops the surge.
protecting your games
you could fuse the terminal block to make it safer.
that could protect a blowback. but high voltage is just that- and it can jump arch and travel through space.
so fuses become spark gaps
25mm ply/mdf wood makes a nice nonconductive base board for power set up
Retroman8392021-01-15 09:52:10
