Help with a 4 player turtles cab
Brettster
1,276CR
A friend of mine just got a 4 player turtles can from eBay
The guy told him it was fully working but it's not the case
I've been to look at it today and managed to get one of the players working
But I'm. It sure how the credit situation works
It has one coin slot and a credit board but inserting a coin or pressing the button on the credit board only let's you play player one
The cab has 4 start buttons on the front that do not work
The player 3,4 cables that plug into the board are not wired correctly
It's a mess I can sort out the wiring for him but I'm not sure about the credit problem
The credit board does not look correct as there seems to be more pins than the connector has
Anyone have any pics of what it should look like ?
The cab seems to have two looms inside with bits chopped everywhere :(
This is the Credit Board inside the Cab
Brettster2015-07-13 21:49:54
FanDabbyDozy
22 (100%)
170CR
If it was the very recent one on ebay, it had the the wrong side art (side art was for midi cab not full size), I think this was not a turtles cab and more had just been converted in to one. Sorry my post is not much help.
5,325CR
simonden
20 (100%)
1,042CR
It uses a 4 players stored credit, credit board such as a Quattro-4. The credit board stores each credit and when it has credits, turns on the lights for the player credit buttons. When the player credit buttons are pressed, it then passes the credit to that player and reduces the number of stored credits by 1.
These credit boards are hard to come by now, so I have created arduino code (for the mega due to the required interrupts), to act as a 4 player stored credit board. It works in tests with jumper wires, but yet to try in a real machine.
Get some pics up of the credit board, you may already have a 4 player stored credit board and just need to wire it correctly.
Brettster
1,276CR
I've posted some pics in my first post of the credit board
if it is the correct one, is there something on the game board to change? it seems to be standard Jamma so has 2 coin inputs
simonden
20 (100%)
1,042CR
It doesn't look like a 4 player stored credit board (it doesn't have enough connectors), just a standard 1/2 player credit board, but to confirm if you can read out the black lettering by the white connector?
Turtles has 4 coin inputs not 2. It has the 2 standard JAMMA coin inputs (player 1 and 2) and also pin 1 of CN3 is coin for player 3 and pin 1 of CN4 is coin for player 4.
If you get stuck, I can release my Arduino code, but you will need and Arduino Mega and an 8 way Arduino relay board and you will be beta testing it.
EDIT: Any reason you want it to accept coins? It is extremely easy to wire it up so those four buttons credit the players without a coin mech/credit board.
simonden2015-07-13 22:49:09
jengineer
49 (100%)
1,205CR
yes it should have a Quattro credit board or similar, so it can credit up 4 players, they are also a bit of a nightmare to wire up unless you have instructions
Brettster
1,276CR
Thanks guys
Wiring up the 4 start buttons would be ideal
From the manual I can see that the 2 connectors for players 3 and 4 have a start button but not a coin input
Does it work with coin 1 and 2 on the Jamma edge for player 1 and 2 and then 3 and 4 coin on the player 3 and 4 cables ?
simonden
20 (100%)
1,042CR
Brettster said:
Thanks guys
We must have different manuals as the manual I am looking at doesn't have start buttons only coin inputs. The cab also doesn't have start buttons, the UK TMHT cab (which you have) has credit buttons and both UK and US cabs use the attack button as the start button.
Just connect the credit button directly to these pins
I can't remember right now if the P1/P2 buttons connect to the credit button or start button, but if your P1 is currently working, look at where the coin line is going to on the JAMMA edge from from the credit board and that is the one to use for the P1 button (and opposite side of JAMMA edge for P2)
simonden2015-07-16 09:09:21
Brettster
1,276CR
Thanks again, Re wired the cab, controls now work correctly, credit buttons now add credits per player and it's all working ok, was a ball ache of a job, but he's happy with it now. shame it wasnt as advertised. but it works
