Help with MVS CBox / Supergun
GDarius
1CR
Hi Lads - wondered if any of you had one of the alibaba MVS / supergun units and could help me with an issue. I set mine up and was intending to run it through my Acer projector that has multiple inputs including component and svideo... if i try component the unit detects the input but cant synchronise the signal... if I use SVideo or a straight AV/yellow cable i get the image but only in black and white...
If I use the component into an OSSC I get no Synch....
Ive emailed china but no answer
Ive also ordered a component to samsung LED adaptor to try on the TV..
Just wondered if im missing something obvious as the device is clearly working and displaying the 161 into 1 cartridge or any jamma board i connect so long as i use svideo and play on black and white !
If any of you are near to northampton and have a " working" one perhaps you could evaluate my unit and if it works we know its either my projector or the cables !
Andy
