help with percentage key
Hello guys have had excellent support and help from this forum doing up my astra red hot 7 machine! :D I'm in search of a manual for this machine - its an astra io3 mpu - I'm having some trouble changing the percentage key and there are some other bits I would like to "tweek" and manual would be just what I need to save the endless questions :p
Thanks in advance :)wiltshirewoodcraft2015-05-31 11:43:12
Just if anyone recognises this problem.... Actual percentage is reading 100.79% - its paying out almost every game I play , and paying up to £150 even though its a £25 jackpot machine. I have flicked the switches back and forth to different combinations on the percentage key but its not budging from 100%
Even if I can just get this down to 90% I will be a happy chap :)
gunblade
9,148CR
some machines don't use a % key,they are done on the io3 dil switches
if it does use a % key then check for bad solder joints on the socket pins
to tell % you need to find aiming % not actual
Thanks for the reply gunblade :)
Iv had a play with the dil switches with no luck and I'm sure its down to the actual percentage key, the key has 4 switches but nothing changes no matter what combination. I have order another key from eBay to see if this helps , it's a guessing game with these Astra's
gunblade
9,148CR
well most astra i work on are £500 j/pot and all % ares set on the io3 dils,normally a min of 88%
many machines have connections for keys but don't use them-only can tell if you have the manual
like actual % will not change via % switch setting-only the aiming % will change
if your io3 battery is shot then that will also affect %,in that case it should come up with a warning message
Thank you for your reply, I understand now, the key connected to the io3 is for aiming the percentage, not the actual percentage.
I have two rows of 8 dil switches on the io3 (sw1 & sw2) would the switches be default to all astra machines or is it individual to the machine?
The machine is an astra 2004 red hot 7.
Many thanks.
Ahh brilliant ! Any ideas where I might find a manual for the dip switches? I think there are some manuals on the mpu Mecca forum but I'm a new member and can't seem to get access to the downloads.
Many thanks
