hi
can anyone help me with what is probably a simple problem that I just cant get my head around
I bought this lopt to try and repair my monitor as the one in my cab has a large crack in it
lopt
as you can see in the description it says to change RESISTOR R447 TO 48KOHM (WAS 33KOHM)
I spoke to ordy and he advised if I cannot find a 48kohm resistor (and I cant find them anywhere) to replace the 33kohm one I can add another resistor to make it 48kohm
sounds simple enough but I just can not find the info I need to do it correctly without blowing my chassis up
I can follow instructions and I can use a soldering iron but that's as far as my electronics knowledge goes
can someone explain to me what I need to do i.e what resistor do I need and how do I link them together to get the value I need?
math
lopt
math
