Help with rs order (sorted)
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Hi all, I am trying to place a small order with RS online tonight.
I need to order the following transistors for my wg6100 deflection pcb but finding them is a mine field.
The items I need are,
2N3906
TPS 98 NPN
2N3904
I don't know the voltage of what I need or the specs I just read these from the schematics and have the same parts already in the deflection board.
I want to order them tonight so I can try and fix the monitor.
Any help would be cool.
Thanks,
Steve. Steve2015-11-24 20:55:57
forcefulfil
EDOT King
17 (100%)
1,675CR
Have u checked the low voltage section first?
Most common failure afterna surge or chassis mounted transistor pops.
My workshop is buried atm so cant tell u the equivalent of the tps but there all on ebay.
Read the tech sheet for a equivalent.
Need to check resistors too these die on the lv part.
Get ur multi meter out and do em allforcefulfil2015-11-24 19:47:49
bonehead
50 (100%)
1,729CR
Thank for the reply.
I have found an alternative which should be a MPSA06.
The deflection board is working but I get a strange curve on the right hand side as if the picture is being pulled to the top right of the picture.
I know the rest of the monitor is fine as I have tried a working deflection pcb in it. I have also fitted a arcadeshop 6100 cap kit and extra parts kit but haven't replaced transistors. Also fitted a lv2000 kit so just hoping these transistors may help.
I will post a picture later of what it's doing at the minute.
