High Voltage Probe?
Megaman255
3CR
I've been watching / reading how to discharge a monitor. They all suggest using a high voltage probe for this and was just wondering which type to get?
Is there a specific one for the job?
Cheers for your help!
ben76
Hunts Spies
1,136CR
I use a flat head screwdriver and a crocodile clip on a piece of wire
On occasions I have used a pair of scissors as I couldn't find my screw driver (prob not recommended that one!)
- Ben
Purity
The Oracle
17 (100%)
2,999CR
Obviously you can use a screwdriver with croc clip, but I'd say for piece of mind use a 40kv high voltage probe. It takes the stress away from discharging a monitor, and you can see if the monitor is giving any readings with a multimeter plugged into the probe.
Also you can't use a screwdriver to discharge a vector monitor.
Megaman255
3CR
Ah perfect!
Thanks for all your replies, think I will buy the one suggested as I've not done this before!
I'm still learning!
Cheers again!
obcd
3,830CR
I took a croco wire and cut it in 2. In between that wire I soldered 2 5 Meg resistors in serie (10 Meg in total) After that, I isolated those resistors with several layers of insulation tape.
I clip one end to a small screwdriver with a large good isolated handgrip and the other to the gnd wire that usually diagonally passes the picture tube and is connected to the neckboard.
It takes like 10 - 20 seconds to discharge a tube like that, but you don't get the big scary spark that you get when you short the HV with a screwdriver to discharge it. You might still see a very small spark as proof that the tube was charged.
Don't forget to discharge again before you reinstall the chassis and the anode cap. The tube rebuilds it's voltage after a couple of hours and can still bite you, even when it was discharged before.
jzatarski
50CR
And ALWAYS connect the tube dag ground before reconnecting the anode cap. I had a small spark jump to me (I had discharged the tube earlier, but it had built up a bit of charge sitting) because of going in the reverse order once. I think the current has to go through the focus/G2 block in that case, so it shouldn't be a big deal, but better safe than dead when dealing with high voltage and capacitances.
Fuzzy
18 (100%)
564CR
I can vouch for this, he really did.
Not wanting to hijack the thread, but my probe is rated at 30kv (I think), not 40kv - is that enough for discharging a monitor?
Purity
The Oracle
17 (100%)
2,999CR
Compare it to doing it with a screwdriver and croc clip
.....Yes I think it will be fine.
Maximum I ever got out of a tube was 10kv immediately after powering off.
forcefulfil
EDOT King
17 (100%)
1,675CR
I have a 30 kv probe here in my workshop.
its just as important as a multimeter if ur in this hobby.
id advise buying one rather than the screwdriver technique tbh.
I also have one u can use to adjust the hv from the anode cap too.
Setch
The nice ad-min
542CR
I agree HV probes won't break the bank and I certainly feel far safer using mine than the screwdriver method.
I still taped mine to the end of a broom handle and wore rubber boots on my first go but that was along time ago before forums like this provided me with the know how to do things and told me what to expect.
Setch
The nice ad-min
542CR
Actually do we have a monitor discharge guide anywhere on here ?
Some small advise I would give are
1) remember to do 2 discharges 5 mins apart as some tubes can hold a residual charge not taken away on the first attempt
2) ideally you want to discharge from the side of the monitor cage and not through it ( if you know what I mean)
Some people also say put your other hand in your pocket that way if you did get shocked it would go down your leg and not through your heart, that's the theory anyway but not sure how relevant that is or if it's an old wives tale :)
Megaman255
3CR
Cheers for all the replies! I feel the confidence building slowly
Def going to buy one now.
Maybe one day I'll try the scissors method, if I feel brave enough!
ben76
Hunts Spies
1,136CR
I have no fear of monitors and it probably isn't wise
I do put my other hand away from the cab though!
- Ben
bomjac
453CR
Proper HV probes.
My mate is on the right with the 33 kV probes, just prior to phasing in a new 40 MW Generator for first synch. I am on the left with the safety hook which would be used to pull him to safety if it went wrong.
jzatarski
50CR
Some
wives tale :)
Electricity through the heart or brain is what kills, and it doesn't take much. I think 7mA is enough to stop a heart, though I'm not so sure what it takes to mess a brain up... Anyway, the philosophy behind hand-in-pocket is that your hand won't be grounded to complete the circuit throught your heart. That way, if you are grounded at all, the current should follow the path of least resistance and the charge will flow on a path different from your heart. Also, sometimes it's possible to stick a ground lead off the tube into the anode cap gently, and that way, it shouldn't regain a charge. Tubes are such good capacitors (being glass dielectric caps) that they collect charge from the air faster than they leak it across the two plates. NEVER assume a tube is discharged, even if you know you discharged it just an hour ago.
Tubes are not supposed to get over 25kV due to X-ray laws, so 30kV should be fine.
Fuzzy
18 (100%)
564CR
Ah, didn't think of it like that, mate!
Mind you, ben76 didn't say what his scissors were rated at.
