home made supergun issues
mathj
499CR
i recently put together a supergun using the plans found on a thread here with in line resistors on the video and wired it to scart
when I plug it into any tv I got in the house (all lcd tv's) I get a really grainy picture (otherwise works perfectly)
is this something to do with the fact that all the tv's I have tested so far are lcds?
I have a old crt in the attic but its a 28 inch widescreen and weighs a ton and I have put off dragging it out the attic just to test my supergun
can anyone shed some light on what I am doing wrong as I built a few of these a few years back and never had a issue, but I didn't own any lcd tv's back then
math
mathj
499CR
this is a very basic setup with a switcher wired directly to the mains
all ground connections are wired to the earth on the plug
GadgetFreak
963CR
I would most likely say it is to do with using an LCD though without a pic it is hard to say.
An LCD has very distinct crisp lines and are not so good at displaying 15Khz signals generally especially as their native resolution is generally much higher. A CRT scan line is generally lower res and not so precise.
sukhbir
46 (100%)
1,736CR
Long wires for rgb can cause problems,also r.f noise from the 5 & 12 volt wires can interfere.putting a ferrite core on these wires can help also the audio wire.
