Hot chassis?
slowcade
204CR
I keep reading that it's important to use an isolation transformer with older arcade monitors, or else you risk to get electrocuted when touching the metal frame of the monitor.
That made me wonder. I purchased a bunch of old arcade cabinets from an operator. He had hacked up the monitors, and connected them directly to "the wall socket". There's no isolation transformer, the monitor is connected to the wall like any TV or PC monitor. He did this in the mid 80s, so these are no modern monitors I'm talking about.
I read that failing to use an isolation transformer would lead to a "hot" chassis. I measured and couldn't find any problem. I can touch the metal around the monitor, no problem.
Does this "hot chassis" problem only apply to the American electrical system?
I also understand that Norway uses IT (Isolated Terra), while most other countries use TN (Terra Neutral), http://en.wikipedia.org/wiki/Earthing_system#IEC_terminology
Does this have anything to do with it?
If so, do I risk to kill someone if I sell these cabs to another country?
RygarR
413CR
Dude, transformers are necessary to change the operating voltage of monitors designed for the US market. Their ac supply is 110 volts, ours is 240 volts. If yours were wired for mains 30 years ago and didn't die, they were probably safe. On the other hand, time could have caused new probs ;-)
tb lilley
5 Star
1,686CR
That'd be a step down transformer rather than isolating (but some do both).
This post gives a few clues as why you should use an isolating transformer. Don't ask me any questions because I understand less than half of it:
Link to stuff I don't really understand but tend to pay attention to
slowcade
204CR
From that thread:
Yes, it is actually necessary for the monitor to work properly. If you connect the monitor directly to the wall power AC without an isolation transformer you will literally AND immediately damage the monitor's main pc board. Likely the power supply diodes will explode along with a couple of capacitors and maybe even the copper foil traces actually blow right off the board!
Uh.. Ok..
tb lilley
5 Star
1,686CR
There's 2 problems - 1 is that a hot chassis is a safety hazard - connect yourself to earth ground (by leaning against a grounded control panel or coin door, for instance) and touch the chassis, you may get a nasty shock.
The other problem if an earth ground is connected to the hot chassis, it will short circuits one of the negative diodes in the bridge rectifier. The monitor goes pop.
For the sake of a few quid I can't see why anyone wouldn't use an isolating transformer when one is required. Doesn't make sense not to, even if the monitor works.
slowcade
204CR
I agree with you, but an isolation transformer hardly costs a few quid? They are quite heavy, so the shipping alone would cost a lot. The ones sold on eBay seem to be rated for 100-120V, and that's not what I need. Where do you buy them?
I'm just baffled that these monitors (and the op.. and the kids playing) have survived for so long if it's as serious as everyone is saying. I'll try to measure between a grounded metal part and the chassis. I tried measuring between earth ground and the monitor frame before, but that was nothing.
slowcade
204CR
strykr said:
Your monitors might be Polos slowcade. they are 240 iirc. No stepdown required.
Thanks, but I think you are misunderstanding the issue. It's not about stepdown.
But you're right, the monitors are 220V-240V. Not sure what make or model, but definitely not Hantarex.
tb lilley
5 Star
1,686CR
There have been a few sold on here for £25-£30, posted. Seems a small price to pay.
There's nothing to be amazed about. It's largely a safety hazard - and it's unlikely that you'd have kids / punters touching a hot chassis.
It's your call - either use them or do without.
gunblade
9,130CR
if you tell us each model monitor we can tell you if it requires an iso
lets be clear though,
if you plugged a 120vac rated chassis into a 240v supply it will blow the primary stage instantly including the fuse
if you are in the u.s and plug a 120vac rated isolated required chassis into a wall socket it will take the trip out as soon as you connect a video signal and possibly blow the fuse
