HOT Question
urbanledge
95CR
thankfully its been a very long time since I worked on any of my monitors....
so long I've forgotten almost everything I've ever learned
Anyway l was looking at at the HOT on a WG K7000 last night and noticed the that it has a bit of plastic between it and the heatsink.
I dont remember seeing that before .
so there is no electrical connection between the hot and the heat shield ?
I always though there was.
M K L
1,158CR
The metal on the back is the same as the middle leg, i.e. the collector that outputs the pulse that drives flyback and yoke. You short that to ground (the heat sink) and you have a broken monitor.
urbanledge
95CR
Thanks guys.
That makes sense .
I've a new HOT on order.
What get damaged if it shorts to ground?
On another note,
can you recommend a thermal paste to use ? I know the PC stuff is a no no.
urbanledge2022-02-25 08:58:27
