How do ROMs fail?
NivagSwerdna
855CR
I am new to Arcade PCBs...
I bought a bootleg Gyruss board off EBAY (which was meant to be working) but I thought I would look at the contents of the EPROMs before even trying to use it.
I found that of the 9 EEPROMS on the video board six are a perfect match to gyruss but 3 EPROMS differ from the published ROM sets by 4, 6 and 1 byte respectively.
On the sound board there are 3 EPROMS. Two are identical to the gyruss rom set but one EPROM on the board reads as all FF whereas the gyrussk.1a in the ROM set contains data.
What do people normally do in this situation? If a ROM differs by a few bytes would you re-erase the chip, reprogram it and try again? or bin it?
What about the one that reads all FFs? Is that a normal failure mode?
(All EPROMS had labels covering their windows)
Thanks in advance.
NivagSwerdna2018-06-17 22:45:00
5,332CR
I've not changed that many, but the ones I've had fail read junk every time and any attempt to reprogram them fails. So the chip circuitry fails, rather than the data contents.
If it's only a tiny variation, it's not a slightly different ROMset to what you're looking at in MAME is it? (e.g. Newzealand Story is 1-byte different beetween regions).
Lurch666
4,519CR
If you have a boot pcb you will find that often some roms differ a bit.That is because boots sometimes remove the original manufactures name from the title screen or make other small adjustments and since there were a lot of boots out there mame doesn't cover them all so I ignore small differences.
If an eprom is all FF then it has possibly had it's window exposed to sunlight over a long period of time thus erasing it or it has just failed.Since yours has a covered window it has just failed.These chips are over 30 years old and were never tested to see if they last that long.
NivagSwerdna
855CR
Thanks. Apart from the all FFs (which is possibly what my EPROM reader gives in the absence of a signal) the ROMs are very very close to the gyruss set... i.e. only 6, 4 and 1 byte.
If I compare to the known gyrussb set I get thousands of differences so I can't really compare it with anything other the gyruss.
The ROM with six differences actually gives varying readings in those six locations so something is up there.
I guess I will start with some 'new' EPROMs and keep the old ones on hand for now.
NivagSwerdna2018-06-18 08:12:22
pobtastic
477CR
...I thought I would look at the contents of the EPROMs before even trying to use it.
Don't do anything until you've just tried it? There are probably a lot of variations which just aren't dumped ~ this is a boot after all. If you've one which differs, try it?! If it works, dump it and send it off to the MAME dev team.
virtvic
The Cabaret King
21 (96%)
2,013CR
Another thing -
Sometimes a substitute sized EPROMs can be used, with doubled up data burned to it. This would fail a rom ident check, but be totally useable.
favouredson
Super Star
1,260CR
NivagSwerdna said:
......one EPROM on the board reads as all FF whereas the gyrussk.1a in the ROM set contains data.
I have had a few instances where a ROM (it has, so far, only been 2716/27(25)32s) reads as blank but the game in question runs properly with it in circuit. I usually just stick it back on the board and forget about it.
Obviously, if the game is faulty with the ROM in circuit then I would look at replacing it.
