How important is the ground hookup on a sega race cab at rear ?
7,202CR
Iv got issues in my r tuned ..
Using Marco multi
( which might be the issue )
At multi menu scrolls down as though service button is pressed.
If I plug Xbox pad in I can press up to stop it ..
In game options no service works
Not even on the Lindbergh ?
Unplugged Lindbergh ran it outside cab not even usb in the io slot ..
No continuous scrolling of menu .
In cab with usb to io unplugged
I have the scrolling ?
Have I got a voltage getting into my ground on this cab ?
I’m starting to suspect Só ..
My cab is in my garage and power was taken across to garage a long time ago ..
I’m not sure I have a good ground going on here 🧐
First I had down on shifter stuck down
Now I have service acting as continually pressed ..
Also if I reset Lindbergh I had
A select normally test button
Automatically select a game ..
Só lookalike I have a short in my io ?
Possibly coming in from a dodgy ground somewhere ..
I guess my options are to test grounds with a multi meter ..
