How to test Ram
tazfaedodge
91CR
After meeting up with John and Mike, I have now been able to test my Double Dragon PCB.
Looks like it now has more wrong after a trip from the Netherlands to Scotland
Still looks like a ram problem (well to me anyway).
So once I have saved the money to get that nice man Gunblade to fix the monitor for my Jamma cab and I then have something to connect the board to, how do I go about testing the chips to see witch ones are fecked?
Or do I not bother about that and just go on fleabay and buy a lot of LS153 chips?
Nick
4,058CR
What's the correlation between LS153 chips and RAM???
To answer the question of how to test RAM we need to know what tech kit you have. If you don't have any then you're pretty much stuck with swapping suspect RAM chips for known good ones.
If you have a logic probe only then you can do some limited testing by looking for stuck inputs, outputs and chip select / enable lines. You can also do this with a scope. Better really as you can actually see if a signal doesn't quite look right, with a logic probe it's a bit of a case of "hmm, not sure if that is spending a bit too long on yellow" etc.
If you have a logic analyser, or better then you can really get funky and look at the timing of the select lines and see what is presented at the inputs and outputs at the time the control lines are toggled and make sure that it's the values you expect it to be. However, I would assume that if you had that level of tech kit then you wouldn't be asking how to do the test (no offence intended).
Also, to do the above test, you'd ideally (but not essentially) also have some way to exercise the RAM and make it do stuff you want it to do rather than just run the game code.
tazfaedodge
91CR
I was talking to someone on a facebook group and was told that the LS153 chips are the ram on the board.
Just re-read the conversation I had, looks like I got things mixed up.
Reading it back he had said that the chips are used for RAM muxing? And think I've just got it stuck as RAM in my head.
And no offence taken I don't have the tools nor do I know what I am doing, and will freely admit it.
Nick
DanP
Administrator
2,232CR
As Gudd says with no test kit the only option you have is to swap in known good ram of the same type. This doesn't mean just new ram I'm afraid as NOS ram can be duff as well. Loads of games from that era use the same ram type (I'd guess it's a 6116 or similar) so shouldn't be hard to find something working that uses the same type. If you have a suspect ram you have pop the old one out and that might mean the real donkey work of desoldering it, putting a socket in it's place and then testing.
If you're really lucky then you'll actually have a ram test built into the PCB software (some are better than others), worth checking the self test settings to see if it has something.
Don't worry about not knowing what you're doing, none of us did when we started. Just be prepared to do a lot of research and reading and you'll get there!
Dan
tazfaedodge
91CR
Thanks Dan
I've already started to get bits here, I've bought some solder braid and break to length sockets. just need to have a good look at the board and work out what chips are what. I've seen that there's boards for sale for stripping of parts and have PM'd about them.
Nick
