HV Varnish
Del Griffith
17 (100%)
844CR
Is this stuff suitable for re-coating round the anode cap area?
http://www.ebay.co.uk/itm/371006071721?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I've seen a previous thread on this but couldn't really tell if this stuff was right for the job or not?? I believe Corona Dope from the u.s is best but probably not possible to import due to it being highly flammable.
A lesson as to why you shouldn't be lazy and let dirt build up and ignore your monitor hissing round the anode for to long!
Cleaned it all off now plus the rest of the dirt and used silicone grease which has sorted the problem nicely, It's silent and running spot on but i fear it's only a temp fix so want to sort it properly.
Del Griffith
17 (100%)
844CR
Yeah i have and it seems pretty ok and no arcing or crackling anymore but thought re-coating it and then applying grease to give an extra seal might last a bit longer seen as it's pretty bad. I've moved the position of the cup to after being advised it may help stop it finding a way through again.
Purity
The Oracle
17 (100%)
2,999CR
I have re-coated an anode cap area with this stuff before. I was getting some serious arcing from a tube, even with silicone grease applied. Once applied to the tube, with a good level of thickness, and allowing it to fully cure, no more arching :)
Purity2015-06-18 18:10:38
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Sorry to hijack the thread but I have a tube that is missing some of the black aqua dack from the back. What would I need to re coat it?
Thanks,
SteveSteve2015-06-18 18:29:29
gunblade
9,116CR
aquadag
http://www.ebay.co.uk/itm/AQUADAG-CARBON-PAINT-ARCADE-MONITOR-TV-CRT-CATHODE-REPAIR-SPARES-30-ML-BRUSH-/261808496366?pt=LH_DefaultDomain_3&hash=item3cf5009eee
corona dope
http://www.ebay.co.uk/itm/10-5002-GC-Red-X-Corona-Dope-SHIPS-FROM-THE-USA-/151688166478?pt=LH_DefaultDomain_0&hash=item235151bc4e
Del Griffith
17 (100%)
844CR
gunblade said:
aquadag
corona dope
You think the corona dope is better and worth the extra cash Gunblade?
Purity
The Oracle
17 (100%)
2,999CR
Good luck getting Corona Dope shipped and imported
The message I got when I tried to buy it was "Sorry but it can’t be shipped overseas. It is illegal to send because it is flammable."
Purity2015-06-18 19:15:27
