Hyper Olympic PCB Issues
Ruben.G
1CR
Hi all, new to the forums. Yesterday I purchased a cabinet with a Hyper Olympic PCB. It works intermittently, sometimes when turned on the screen is filled with o's and random graphic, sometimes it works fine after a reboot but freezes and screen fills with N's. Also where the records and scores are is just a random character. Any help would be much appreciated! Cheers, Ruben
Purity
The Oracle
17 (100%)
2,999CR
That image above is a classic sign of not enough voltage to the PCB. It needs just over 5 volts, like 5.2 ish. As said 5.7 is way too high so you need to turn it down
Ruben.G
1CR
philmurr said:
Ruben.G said:
All sorted!! thanks a lot, guess that's me for the rest of the night!
How did you fix it?
As above, if you're running the board at that voltage you're going to do it some serious damage.
I cranked up the +5 to about 5.2v and turned it back on, booted straight up. Still have this slight issue of scoreboard up top right
Purity
The Oracle
17 (100%)
2,999CR
Score board corruption is normal aswell. You might need to replace the CR2032 battery, however there is a DIP switch to reset the scoreboard on powerup. That will fix that issue
Ruben.G
1CR
Excellent, will try that now. Thanks so much for all your help!
