Hyper Sports PCB problem
Purity
The Oracle
17 (100%)
2,999CR
Hey guys, I've got a problem with a Hyper Sports PCB where there are lines through the swimmer and gun at the start. I've not checked other levels but suspect this appears in later levels aswell
I thought I'd ask if anyone has seen this before?
I'm going to look through the rom sets now to see if it may be an issues with a rom
Purity2014-06-08 23:07:41
RGP
Meeter & Greeter
2,039CR
Sprite RAM is 2114, lower board, there's 4 in a group, (can't remember exact location) but probe around there, they seem to be the sprite object buffer if I remember right.
Are the other swimmers having lines as well?
RGP2014-06-09 01:29:17
sukhbir
46 (100%)
1,734CR
hi,have you checked if you have +5 volts at the games non jamma edge connector? sprite issues can occur with a drop in voltage,some jamma made adaptors have thin wires where you can get a drop in volts.
Purity
The Oracle
17 (100%)
2,999CR
Here's a video:
I made the adaptor so the power wires are a good size.
I'll take a measurement at the PCB and see what the +5 is like. I could also try cranking up the power supply a bit
RGP
Meeter & Greeter
2,039CR
So your problem is jailbars but the interesting bit is that its on accessing certain sprites.
Notice how the athlete has no jailbars on the vault until he goes through the jump/spin animation.
I would still think RAM initially as there's 2k of sprite ram and we don't know which bit of memory its using at what point.
Purity
The Oracle
17 (100%)
2,999CR
All the pins are pulsing as I would expect on 10J 11J, 10H, 11H
All the pins are pulsing on the 4-bit rams on 8J, 9J, 8H, and 9H, apart from pin 8 which is low on all of them
Purity2014-06-10 18:37:09
RGP
Meeter & Greeter
2,039CR
Pin 8 low on 8J, 9J, 8H, 9H all the time? pin 8 is /CS and is active low.
Here's the standard Konami Hyper Sports badly drawn schematic:
http://arcarc.xmission.com/PDF_Arcade_Manuals_and_Schematics/Hyper_Sports_Schematics.pdf
I hate this schematic!
You'll see on the first page, that the 8J/9J/8H/9H pins 8 and 9 are tied together to ground which is why you're seeing that.
Your jailbar looks like every 8th pixel on the video this kind of suggests that there's a stuck buffer then if its not the ram (you have good activity on all the D lines (11,12,13,14) of the 2114's).
I'd follow the databus at this point up to G9/G10 (2x2128's) and their associated 244's and 245's maybe the data is coming out stuck not leaving stuck.
Purity
The Oracle
17 (100%)
2,999CR
Ok this is really weird. I've lifted the board as I was looking at the chips and the jailbars have gone.
I'm wondering if it is a problem with the ribbon cables between the top/bottom board? Or it is an intermittant problem
I've powered off a number of times and back on and it looks fine. Not that I'm complaining :)
Purity
The Oracle
17 (100%)
2,999CR
This problem re-occured today so I took another look at it.
I looked over all the eproms and saw that one of the pins looked odd, so I lifted it out of its socket and pin 1 was bent in half. I carefully bent it back into shape without snaping it, and put it back into the socket.
....and the game works fine now with no jail bars!
Really simply fix!
Purity
The Oracle
17 (100%)
2,999CR
silverfox0786 said:
haha cool
love it when a plan comes together
although you should have checked that as the very first thing
True, but as above the problem went away so didn't look into it any further.
Clearly it was making good contact at certain points and not at others
Purity2015-04-25 18:56:19
